Wacky Temperature Readings
754
Oday 28 Madison, CT
I have been seeing erratic readings on my M12 Universal Water Temp gauge. Min readable is 120 degrees, but sometimes I am seeing 150 when the engine is dead cold. Tapping the gauge does not get it back to min. Before I start replacing sender/gauge etc, I thought I would look for sloppy connections. Can anyone direct me to the location of the gauge sender on this engine? I want to check and clean, possible replace connector and see if this cleans up the issue.
www.marinedieseldirect.com
Click on Universal, find your engine and then search in the "group" sections.
Good information to have available to you, bookmark the site on your computer.
Good luck.
