I want to drain the antifreeze from the engine, and the hoses and heat exchanger on the hot water heater. There is a fitting (picture attached) in one of the hoses. Does anybody know what the purpose of this fitting is? It is a Schrader valve (air fitting). What method do you use to drain the coolant? I see the 3 drain fitting on the engine, but I am not sure how to drain the hot water. Thanks.
George
George
