Rust is virtually guaranteed and nothing you do is ever going to eliminate it completely. That being said, it shouldn't be a deal-breaker if the boat has been well maintained. Very common issue on many thousands of externally ballasted keels.I'm looking at an '84 Hunter 34 with cast iron ballast. How real is the corrosion issue with this material in an older boat?
You know, what I never hear about is glassing over the keel. I had a 26' T-Bird for 19 years that had a fiberglassed iron keel. I had a bubble on it once and I just ground off the area and reglassed it. No big deal. Wonder why more are not done that way?I'm looking at an '84 Hunter 34 with cast iron ballast. How real is the corrosion issue with this material in an older boat?
Is there any reason to NOT use coal tar epoxy and fiber glass to enclose an iron keel? I believe that with some careful planning you could apply enough glass and epoxy to effectively change an external ballast keel to an internal ballast keel.You know, what I never hear about is glassing over the keel. I had a 26' T-Bird for 19 years that had a fiberglassed iron keel. I had a bubble on it once and I just ground off the area and reglassed it. No big deal. Wonder why more are not done that way?
