We finally got the Pearson hauled this weekend to install the rudder. The keel hull joint is all cracked up, which from what I read is pretty common. The boat has been in the water for at least 5 years as good as I can tell, and it does not leak from the keel.
We didn't spend alot on this boat and it stays in fresh water. I was going to try and do this repair without having to repaint the entire hull and fair the whole keel. Any advice on materials to use for the fairing? I'm a little confused as to whether you use glass cloth around the joint or just epoxy with filler.
Pictures attached show big cracks at rear, crack along port side, and "bubbling" on leading edge of joint.
