I need to replace the forestay cable on a Venture 21. Do not know the exact length or what vendor could supply the cable?? knhanson@tds.net
The cable looks small like 1/8 in. and measures 20 feet end to end of loop fastened with a cable tie/clamp. Same small loop on both ends. Will look up bosunsupplies.com and see how to order the replacement. Thanks!You just need 1x19 stainless cable probably in 5/32" or perhaps 1/8". Makes no difference the manufacturer. But, in addition the supplier needs to know the end fittings. Whether they are swaged terminals (forks, MS or AC eyes) or Nicro Press oval sleeves with thimbles. And you have to know the exact length of the cable. If you broke the original, measure the pieces.
West Marine?where can I locate a aview of end fittings for forstay cable.// IE: swagged terminals, forks, MS or AC eyes, or Nicro Press oval sleeves with thimbles. Do not yet know the terminalogy
on this??
the early macs all used nicopress sleeves on the rigging. if you have a local rigging company make you up a forestay, make sure they use copper sleeves and not aluminum.where can I locate a aview of end fittings for forstay cable.// IE: swagged terminals, forks, MS or AC eyes, or Nicro Press oval sleeves with thimbles. Do not yet know the terminalogy
on this??
