Helped a couple the other day. They were motoring into the marina in their 26 foot trailer sailer when their outboard quit. They were motoring from one marina to another, so their mast was down. They were in quite a panic. The decks were covered with rigging. the husband tripped and nearly fell overboard while coming forward to throw me a line. The heavy wind was blowing them toward rocks on the far side of the marina, and the husband couldn't get a 25 ft line to me... 30 ft away.
He realized his predicament, and he returned to work on starting the engine. Seemed like an idle jet clog with maybe dirty gas, too. The motor would start, rev, and die as soon as he reduced throttle to shift into forward.
The wife was panicky, so I told her to check for an anchor, make sure it was tied to a line, and lower it into the water under the bow pulpit, then tie it off.
She did; the anchor caught, and she immediately looked relieved. The husband got the motor started, and they asked me where their slip number was. I showed them where it was, and they got half way there when the motor quit again. They drifted in, and I eased them into the slip.
Lots to be learned here!
Are your decks tidy?
Where is your tow line?
How long is it?
Where is your anchor?
Is it ready to use?
When did you buy clean fuel?
Do you run the fuel out of the carb and lines every time?
Does your mate know how to sail or motor? If you go overboard, you will wish he/she did!
Do you know how to clear a clogged idle jet?
1. Remove the air "cleaner" and spray some starter spray or carb cleaner in the carb.
2. Start the engine ( it will rev above idle to start. The motor starts at about 35-40% throttle)
3. Rev the engine.
4. Put your hand over the carb to choke it while it is running at high rev.
5. Repeat #3 and #4 several times.
This will cause the engine to draw fuel forcibly through the idle jet. It may clear the clog.
6. If you are berthing in a new place, did you take time to find your new slip? This couple had dropped a car at the marina, but they didn't know where their slip was.
How well you prepare for an emergency will determine how comfortably you handle it. The couple in this story wasn't ready. They need to make friends with their boat again. Their boat was blushing a little after this episode. It was wishing for better prepared handlers. All these were little things, but they added up.
Me, I would have pulled myself to the dock with the anchor: throw it, pull myself forward, pick it up, repeat.
Andrew
How long is it?
Is it ready to use?
3. Rev the engine.
Andrew
