Hello folks,
I have finally fabricated a set of vertical swinging doors to replace the annoying slat boards on our 2002 Hunter 356. I used 3/4 Starboard material. The doors will have lexan clear window slide-in inserts as well as slide-in screen inserts. In all I have about 4 hours in fabrication.
Here is where I could use some help; The doors will swing inward. I plan to use "slip" hinges on the inside to assist opening [able to life upward 1/2" to clear the bottom track]. I have searched the world over for "slip" hinges and all I find are "lift off" hinges. Of course that would work but I did not want the door comming off in my hands everytime I lifted it up to open. I was thinking that "slip" hinge meant you could lift the the door up to open and it would not come right off the hinge pin. Does anyone have any info on this?
Please check out the attached photo of my creation in process [unsanded phase].
thanks...
...Jim and Kathy departing Folsom in 10 days for a summer of Sailing on SV SamiDog currently on hard in Boyne city,MI
thanks...
