Prepping the boat for the season and discovered fuel dripping from the bottom of my fuel tank. Aww crap!
Crawling around the engine bay to change filters, etc. I noticed some moisture, seemingly coming out from under the fuel tank. I cleaned if up and for sure, it was diesel fuel. I got a good pic of the bottom of the tank using my iphone and I could see a row of droplets forming. Looks like it's time to replace the tank. What the hey, it's 35 years old!
Problem is, the fuel fill is in the cockpit sole, just inches away from the fill opening in the top of the tank. I'm not sure where I'll get another tank that will come close to having the fuel fill opening in that location, short of having one custom made. I'm thinking of pulling the tank and seeing if it's worth using Caswell's epoxy tank liner on it. I've used it on motorcycle gas tanks in the same shape with good results.
Otherwise, I'll have to pull the tank and get some good measurements on the fill opening location, and shopping around for a stock plastic tank.
Anyone else replace their fuel tank, and if so, what tank did you use, etc.?
