I have a 2007 Hunter 33 which has a rain leak into the engine pan.
The water rises in the engine pan until it is about 1 inch deep, as a lip prevents water depth less than 1 inch from draining intro the bilge system. After the pan fills up above 1 inch, the water above 1 inch drains into the bilge system.
This water only accumulates after a rain. If it does not rain, no water accumulates, so the water is from rain, not some other problem.
I have tried 2 times to simulate rain using a hose, to no avail, not being able to find out where the water is entering and leaking from which ultimately fills up the engine pan.
I am seeking a Hunter 33 owner who has experienced this same engine pan rain water leak problem, to let me know where they found the rain water leaking from.
Mike Hunter 33 Rain Leak
