After launching and hauling it back out due to a leaking brass fitting, I've been thinking... I have seen the through transom drains from CD. I don't like them because the cockpit floor drains to the front. Holes in the rear would have to supplement the factory drains. I would like to glass up that hole in the bottom of the boat. My thinking is just pie in the sky right now, but... What if you used standard plumbing stuff and enlarged the drains in the front of the cockpit. Then, elbow them toward the transom with enough slope to drain. Lastly, thru hulls under the cockpit floor but above the water line. It would be easy to go 1 1/4 to 1 1/2 all the way out the back. I suppose standard thru hulls could be rubber hose joined to piping from modified floor drains. I like the plan in my head, but in practice it may not work.
All of the water in my boat since I bought it came from the cockpit drain in the floor leaking rain water in or from the brass tube leaking lake water in.
If you have one of these boats, and you don't know if its been resealed. I'd look at it before my next launch. It is so simple to repair while on the trailer. I was surprised the NOTHING holds it in except some 30 year old sealant. If it were to slide out you'd have a 3/4 in hole in the bottom. I removed the rubber hoses on mine and basically just pulled it up out of the floor.
