Is The 352 Prop Rt Or Lt?? What Prop To Get??
92
beneteau 352 Raritan Bay
hey guys,
im almost ready to drop her in the water.. sent the prop out to get reconditioned and the boatyard said it had a crack in 2 of the blades close to the hub :( not good... so .. they told me it is a 16" 13 pitch .. so before if bought new I thought id check out the salvage sites online.. and.. I found one for $95 .. and its a right with a 1" bore...which leads me to the question....
is this the one I want??
boat is a '99 352..
thanks
jason
Nov 24, 2012
586
hey guys,
boat is a '99 352..
thanks
jason
I would call Beneteau in Marion with your hull number. They'll give you the specs on prop size, pitch and rotation. Yards have been known to be wrong. Also double check shaft diameter with them to make sure it's not metric.
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
Mine is a right hand prop which kicks the stern to port when reversing in a slip.
Beneteau 323 Annapolis MD
One inch (25mm) sounds like a small shaft for your 35? Also look at Baconsails.com for their used ones.
May 24, 2007
185
Beneteau 352 Milwaukee, WI
Shaft Diameter
All Beneteau's, French or US built, come from the factory with metric shafts. Our B352's have a 25mm shaft unless somebody changed it since it was built.
Factory prop was a 3-blade 16" x 13" pitch. One day, after I win the lottery, I will replace it with a Maxi-prop feathering prop.
Feb 8, 2013
92
Factory prop was a 3-blade 16" x 13" pitch. One day, after I win the lottery, I will replace it with a Maxi-prop feathering prop.[/quote]
I agree.. theyre nice .. but I just cant see spending the $$$ on that right now.. I have other things I need to but first..
Mar 28, 2010
15
Beneteau 352 - hull 235 Rock Hall, MD
Go for the Max-Prop! PO put one on our '98 352 & it's great! Nearly no prop walk in reverse.
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
I agree on the MaxProp. Put one on our boat a few years back and have no regrets. Yes, cost a little bit more, but very happy with it.
Feb 8, 2013
92
thanks for the info guys.. found one at minneys yacht surplus for $95.. ill go with that till next season or the next.. but I agree , id love to get a folding or feather prop ..
