Under no conditions should you do this
This will be much more convinence for me as the Y connection on the incomming cable maks a lot of trabbel.
Is it ok to combine the 2 waires on the boat to one plug only?
My friend,
There are very straight forward methods of connecting shore power to boats.
If you use anything other than ABYC approved wiring connections, you risk electrocution.
Rule of thumb on a boat. Unless you really know what you're doing, don't mess with the shore power wiring.
I can't stress this enough.
Speaking of which, I want to point out a safety tip that I want everyone to follow. 100% of the time. Not 99%
Whenever you are either:
Leaning over your engine
Working in a cockpit locker
Accessing anything where you are up to your elbows
Unplug your shore power !!!!
At our club many years ago, a guy was working on his engine.
Real sweaty, and his chest was draped over the engine block.
When he straightened up, his neck touched a live 120 wire.
Lights out.
You never know if a previous owner ran a wire somewhere, or if an installer made a mistake. Never take a chance. Unplug your boat.
If you have an inverter, make sure its off. It will electrocute you the same as shore power. If need be, turn off your battery switch.
