I have the Electromaax 140 Amp alternator, with Sterling Pro-Digital regulator, I do not have the remote control for the regulator. I have about 400 Ahr AGM house bank.
If I am in the slip with the Sterling battery charger on, with the bank fully charged, so it is floating at 13.3 volts and few mA's going one way or the other. Then when I start the engine (the battery charger is off of course) and the alternator voltage goes quite high around 14.7 volts, with about 8 amps being accepted by the battery bank, the voltage and current seems to jump around quite a bit like the regulator is analyzing the battery. After a bit, the voltage is reduced to 14.5 V and about 2 amps are being accepted. It has stayed like that for a half hour or more until the engine was shut off.
From the owners manual it appears the regulator has entered a timed period of 1 to 6 hours at the high charge rate before it will go into "float" mode and reduce the voltage to 14 volts. I have the regulator on the AGM setting.
The battery label indicates it should be charged at 13.8 to 14.6 v and floated at 13.2 to 13.6 v. I am concerned if this could hurt the batteries by running them at such a high voltage when they are already fully charged ?
Bob
Bob
