Overheating tip
515
Hunter 320 Williamsburg
Upon firing up for the season, my impeller didn't work properly even though it was newly installed last fall when I winterized. I theorized that it was my fault for turning the camshaft once a month over the winter to keep the impeller flexible (something I learned on this HOW site). My supposition was that it inadvertently created a vacuum between the pickup jar and the engine because I was unwittingly pumping antifreeze out without replacing it with anything. The mechanic gave me that blank look that I get when I explain things to my wife.
Regardless, here's the takeaway. I asked him how he could be certain of anything since my H320 was thoughtlessly designed with the exhaust exiting under water so you can't tell if you're pulling water. His response was to feel the cover of the water pump to see if it was warm or hot, hence spinning without pumping. Pretty clever, and a lot easier than taking the thing apart for a trial-and-error expedition of overheating engine.
Jan 4, 2006
7,870
Having the Exhaust Underwater .................
............................. was a bit of a bummer until I installed a flow alarm in the line leading to the raw water pump. Problem solved.
I really don't think it's necessary to flex the vanes of the impeller in the raw water pump every month to keep them flexible. I leave my engine over the winter and maybe wind it up once or twice with the unloaders open just to oil up the cylinders. And I have OCD with my engine.
Actually, over the years I've really grown complacent about my raw water impeller as it seems to be utterly indestructible (Yanmar parts). When I bought the boat new, I started with opening the pump and checking every year ........... perfect condition. Downgraded to checking every three years. Changed it out when it was eight years old. Looked to be in perfect condition, but you just never know. The new one's been in for five years and I've never looked at it. Running hours, about 130 HR/year.
I spend far more time monitoring carbon build up in my mixing elbow, valve lash, chasing oil leaks, etc. Raw water impeller is just about the last thing on my preventive maintenance schedule for the engine.
Hunter 29.5 Gloucester, VA
I'm working towards what Ralph is doing Bill. I replaced mine this spring after two seasons and it still looked pristine, soft, supple and no cracks. I even kept it as an emergency back up.
Have you considered simply removing the impellers during the winter? That's what most of our skippers do, but the Oberdorfer or Sherwood pumps on our M25 or M35 series engines may be much different than yours.
Sep 29, 2008
12
Hunter 326 Vaasa
I have simply installed reinforced transparent hose so I can see the water flowing.
