Plumbing
320
-Irwin -Citation 40 Wilmington, NC
Looks good always nice to make improvements like this. I might suggest at the water heater you secure those water lines so that they are not damaged by stowed equipment. Hard to tell in the pictures but I am hoping you secured the heater as well. What type of heater is that by the way? Good job I am sure it will make your boating better.
Capt. Wayne Canning, AMS
www.projectboatzen.com
Feb 1, 2010
210
Hunter 33.5 El Dorado Lake, Kansas
We are lake sailors so we are docked a lot so I put in a 110v 2.5 gal. water heater. The tank is secured to the bulkhead. The biggest improvement was the smell.
Jul 25, 2007
320
Cool nice looking little unit. Just make sure the neutral and ground are not connected in the heater as some home unit do this. looks like some nice improvements. I do like the Plex tubing over the hose builders used to use.
Nov 10, 2012
62
Catalina 36 mkII Havre de Grace, Maryland
We replaced all the plumbing with new tanks, electric toilet, faucets, water tank and pex lines.
What size is the water tank did you choose to go with? Where did you purchase from?
Thanks!
Ed
May 27, 2004
2,057
Boy, Am I confused...
Your Avatar says S2 8, but the pics are of a H30 C???
Nice job by the way and since my water heater just died, please tell the group the brand and model number of your new one.
Thanks.
G.
Feb 1, 2010
210
Thanks!
Ed
I put a 13 gal Todd's in place of the old 33gal water tank. I also pull the septic bag and placed a 13 gal Todd tank in the same area. The Todd Part #: 85-1626WH. It's 24"x10x14. I hope this helps.
Feb 1, 2010
210
Thanks.
G.
I put in a Reliance 2.5 Gallon Electric Water Heater, it a 110v unit that can only be used at the dock.
I have tried to change the S2 and for some reason it don't save it. But we are now a Hunter fan.
