Boom,
Alas another bottom paint thread, with the final solution for all areas still not in sight.
Maybe the next generation of bottom coatings will work better.
Different areas have different problems with types of paint to use.
I have used various "running gear" applications, and after $$$, in my area does not hold up.
I sail out of Madeira Beach on the left coast of Florida. No paint system works for me because I sail out a pass with sometimes up to a 4 kt. current. An outgoing tide has a large amount of sand etc. suspended in the water. Hence, each time I come & go, I have sand papering effects on my shaft & prop.
I have never had a system that lasted more than 6 months, so I've given up this practice. I use a scuba guy once a month & have had no troubles.
Not being familiar with your area, could it be that there is sand suspended in your water, & maybe the culprit?
CR
