I need a few new stanchions 1982 Hunter 25
Cut
Mar 30, 2013
5
Hunter Hunter Cherubini 25 Brick, NJ
My Cherub Hunter 25 was damaged in Sandy. Three of my stanchions were bent over when the boat flipped off it's stands and washed into a marsh...... I need to replace three stanchions that are badly bent. They fasten with with two bolts through the rail extrusion and also through the deck with another two bolts. I''m hoping someone has some used available, I believe they are beyond repair. Are they available new somewhere? Thanks again! C
Apr 16, 2012
22
Hunter 25.5 Chelsea NY
There are some listed on the site for sale. They seem pretty expensive depending on what you are replacing.
Can they be at all straitened?
Cut
Mar 30, 2013
5
Thanks Begynol!
I'm not sure if they can be straightened, they are quite kinked at the base. I'd prefer to simply replace them in one step if I can. I can't find the ones ( the ad) you mention that are for sale here on the site, is it possible for you to send me a link to that ad? Thanks! Regards....
Cut
Mar 30, 2013
5
Thanks Stu!
Garhauer can make anything.
I know Garhauer is a great resource, I didn''t know they fabricated! Thanks for the tip Stu, if I can't come up with some used ones maybe I'll have to send a bad one to Garhauer and have three made.... see what develops! Thanks!
