Sumner,
when I first saw your anchor roller set up I thought it was perfect and i wanted one. so i set out to build one kind of like it, but as i got into it things changed and I thought rather than build a one piece unit, i would build it in two parts, one for the left side, and one for the right side, so then they could be built at different times.... as i was building it, it somehow morphed into what it is now
all this was done on my first boat. but i never got around to building the starboard side anchor roller...
the design worked so well on Allusion that when i wanted one on this boat, i designed it to run right down the centerline of the boat... and incorporate the stem fitting into it.... so it had to be stronger and be able to take a load from any angle....
about the swivle/pivot.... as you are well aware, its extremely difficult to impossible to get an anchor shank over a fixed bow roller, depending on the angle of the pull on the rode.
but no matter what the weight of the anchor, when the roller is allowed to pivot, the angle of the shank entering over the lead roll is softened (and extremely variable with boat motion)... which is dependent on where the pivot is located between the rollers.
with the pivot at the proper spot and the heavier the anchor, the farther the lead roll will dip to allow access for the shank over the lead roll. with the pivot being farther back, the roller could tip way down and the shank could have almost a straight shot in over the roll without resistance, but then the lead over the second roller back will be sharper and its possible the anchor may be too bottom heavy for the whole apparatus to tilt back with a reasonable amount of force.
having the pivot out a bit allows for a better balance when working
and stowed...
the "balance" being, the force of the rode pulling over the second roll as it tries to tip it back and lift the nose roll,... while the shank is against the nose roller pulling it down trying to gain some lead over it....... the pivot pin in the right spot will allow it to balance for its own needs as the anchor is drawn into it....
when I mentioned 'extremely variable with boat motion", i mean that when when the roller allowed to adjust itself, and the anchor swinging as it does when the boat has any motion, a very heavy anchor can be brought over the lead roll with very little more effort than it takes to hold it....
for the rode going to the cockpit....
I use a medium kitchen size rubbermaid trash container for my rode to lay in. when im weighing anchor it is in the cockpit so the rode can flake into it.
but when its not being needed for flaking, or when deploying, it sets in the cabin directly below the companionway (the 25 has a spot there that is mostly out of the way for whatever is stored there)
the 10 feet of chain i use works well with this set up, but for more secure anchoring in general, more chain would be better.
I have several thoughts about, "what if I wanted to add more chain?", and how i could manage it with this set up....
I could just go to the bow and do it like is normally done....
also thought about taking a piece of outdoor carpet that would snap down to the deck under the track of the chain/rode to protect the deck....
Or, i could install PVC tubes for the path of the rode.... this would keep the chain off the deck as it runs to the cockpit.
I think with a flared end fitting on the PVC tubes that they wouldnt need to be attached to anything, but just have the chain ran thru them. it would just ride the chain and float between the leads as the chain passed either way thru it. when i removed the rode, the tubes would be stowed and not on the deck....
with the delrin lead blocks i made, the chain runs around them about as easy as if it were a roller, and they will last a long time. (working delrin is about like working aluminum. its hard stuff for being plastic)
lots of ideas but I dont have a need for the chain yet... but I have thought about a 25lb weight to run down the rode when on a short scope or for more cushion if anchored in rough conditions. I know the security of chain can be beat, but i dont have the need for more chain YET....
And dont get me wrong,...I like being out working the foredeck also, but in rough conditions when the boat is dancing the wild fandango and the spray of the waves hitting the bow is a bit too refreshing, weighing the anchor from the cockpit is just better
