fuel fill hose versus exhaust hose ....
6,244
S2 9.2a Fairhope Al
......is it possible to use fuel fill hose for exhaust hose with out any problems on a wet exhaust system...or is there a danger of fire or carbon monoxide.........
regards
woody
Jul 25, 2007
320
-Irwin -Citation 40 Wilmington, NC
I would not personally do it. Fuel hose is not designed for the heat and hot gases the exhaust hose is. It might work for awhile but in the long run I think the hose would fail. A blown exhaust hose can make quite a mess in your engine compartment.
Capt. Wayne Canning, AMS
www.projectboatzen.com
Jun 6, 2006
6,990
It would have to be a pretty small engine as I've never seen fuel hose bigger than 1/2" so I'm thinking that even if it could (doubtful) it would not work due to not being able to get it over the outlet.
Jan 30, 2012
1,154
One way to decide is to follow the manufacturers' rules.
Federal standards do not apply to recreational diesel fuel fills nor to exhaust hose but ABYC standards are written for both. ABYC adopts SAE standards that apply to fill hose and adopts a separate SAE standard for exhaust hose. Certain ABYC approved fuel fill hose also meets the separate exhaust hose standards. For example, fill hose designated A1 can typically be used for both fill and exhaust.
The obvious point is that the hose manufacturer labels the hose and will tell you in their catalog whether their fuel fill hose can also be used for exhaust hose.
Charles
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Charles
thanks Charles that is the answer i am looking for...and thinks to all the rest as well......
regards
woody
