I chose the only boat in the world that an X-5 AP doesn't fit.
I love that the boat was built with a 4-post pedastal. Looks good, very robust. However, the bridge that supports the aft posts (rails), which houses the throttle and transmission cables, interferes with the X-5 clutch handle. Found this out during installation today.
I can't mount the motor on the top left, which is the other option, as it colides with the bridge on the other side. I have to mount it on the lower right. It ALMOST fits. If I back the wheel nut off a little and pull the wheel back, I can use it. :lame:
What I really need is a different clutch handle. Has to be only a 3-4 mm thick to fit. Metal would work better due to the thickness.
Anyone else have this issue? Know where to get a custom lever? Any other ideas?
