Loose Wire
147
Hunter 36 Mulberry Cove Marina
I have a Yanmar 3GM30 and I recently discovered a loose wire located on the harness behind the alternator and oil filter. I used a mirror to try to locate where this wire would connect but could not find an empty connection. I have attached pictures of the wire in question and appreciate any assistance.
Jan 30, 2012
1,147
No worries - check your Yanmar manual for the diagram. Yanmar manuals designate the connector as "spare. " In fact the connector is available for the Yanmar seadrive. The wire colors (should be) black and white.
Charles
Nov 6, 2006
10,118
exactly.. goes to the sensor in the space between the diaphragms on the saildrive .. turns on that lamp in the panel to tell saildrive people that it is past time to take the boat out of the water.. and put a new rubber boot in.
Oct 4, 2008
147
Thank You
I appreciate your help. I can sleep well tonight.
Charles
Oct 4, 2008
147
Thank You
Appreciate having friends like you helping me out.
