Using a Gennaker from a Pearson 323
360
Catalina 310 Gulfport Small Craft Harbor, MS
A friend of mine has offered me his Gennaker from his Pearson 323. I would guess that his boat has similar size mast to my 310 so I am hopeful that it will fit properly.
I am presuming a Gennaker is sort of a cross-breed between a Genoa and Spinnaker. It is a much lighter weight material than my current Genoa but it is not as thin as the Asymmetric Spinnaker on my smaller boat.
This Gennaker also has a thin bolt-rope which I think would probably fit in the groove on my head foil so I might be able to drop the Genoa and fly the Gennaker.
But does anyone have any experience at flying a Gennaker with a loose luff...like a Spinnaker...but with a thin bolt rope. Would it work that way. And I could keep the Genoa up but furled if I did this.
Guess I will have to take it out and try it.
Appreciate any thoughts, insights, comments.
Cheers,
Jim
Sep 29, 2008
1,954
Catalina 310 #185 Quantico
Take it
A Gennaker is a nice light sail. I expect you would be best served sailing it like an asymmetric spinnaker. I do not think it would be a good idea to try and fit it into the groove on your furler. Of course you might be well served to put it on a spinnaker furler if you wanted to put the money out. In that way you could get the best of both. :D
It should be .75 ounce nylon or similar.
This says it is for a boat up to 23', but perhaps there is a slightly larger one. http://www.westmarine.com/webapp/wc...gclid=COGIpIm4_bUCFQZV4AodqmMANw#.UUJoptbqjhs
deke
Jan 5, 2011
31
catalina 310 charlevoix
Cheers,
Jim
Hi Jim, many earlier asymmetrical spinnakers were called gennakers and I have seen some with that thin luff rope. It was provided to strengthen the luff only and not to be installed into the forestay foil. It works well on a broad reach from about 40 deg. To 140 deg. apparent. I tack mine down to he bail on my anchor support and run the lazy sheet outside of the stay to allow an outside jibe. Both sheets run back to the normal spinnaker blocks at the stern. Where I can't run dead down my increased speed more than makes up for the added distance. Deke
Mar 22, 2009
360
Thanks for the info. I am going to fly it tomorrow and see how it works.
But the thin bolt rope sure looks like it is designed for a furler as the bolt rope does not connect the head and tack but is out on the edge of a seperate strip of cloth (maybe 1" wide). If it is not in the furler the bolt rope would not hold any tension.
I am going to try and fly it both ways and see how well it works. Would rather use it flying free so I can leave my Genoa installed.
Will report results tomorrow.
Thanks,
Jim
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
c130king
"But the thin bolt rope sure looks like it is designed for a furler as the bolt rope does not connect the head and tack but is out on the edge of a seperate strip of cloth (maybe 1" wide). If it is not in the furler the bolt rope would not hold any tension."
Worst thing that comes to mind is the 1" wide edge will chatter.....but you will know tomorrow......:+1:can always take off 1" edge :confused:
Well worth the try.
paulj :troll:
Mar 22, 2009
360
Paul,
That is exactly what I was thinking...the dreaded "edge chatter"...only topped in the annoying sounds category by "fingernails on a chalkboard" which has just about become extinct because everyone uses whiteboards now.
T-minus 5 hours until I launch it.
Cheers,
Jim
Mar 22, 2009
360
Ok. Flew it today but only as a loose Asym Spin. Didn't have time to take off the Genoa and run this new Gennaker up inside the foil. Next time.
May be a little bit large but not by much. Flew from about 150 degrees off the wind up to maybe 80 degrees off the wind. Big power in 12-14 knots of wind. Was doing 6.7 knots.
Need to rig a better tack line attachment and run the tack line back to the cockpit. Probably mount a bail on my anchor roller as mentioned above and then mount a block to the bail for tack line led back to the cockpit. The clew is way back behind the mast...maybe 165% is my guess. Red, white and blue so it looks nice.
In light winds I could probably pole this Gennaker out with my whisker pole. I think it will be a little bit easier to manage in winds under 10 knots.
And I did not notice much "edge chatter" so that is a good thing I guess.
Cheers,
Jim
deke
Jan 5, 2011
31
Cheers,
Jim
Hi Jim, With having re-read your luff rope description, I now think your sail is intended to be furled. Code "0" sails are usually run up on the headstay and the luff is kept straight but not as large as what you have described, where the more recent aysm sails that have their own furler have a torsion rope sewn into the luff. The torsion rope does not twist as the furler is wound and therefore
rolls the sail up. These are usually about as large as your sail and flown with a significant camber on the luff, don't point as high as the code "0" but I think they are better downwind. I not sure where your sail fits into design intention. Sounds like it might make a good free flown aysm if you can get rid of the luff rope. If it flies well, look into an after market sock like the ATN. Deke
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
I rig my big reacher inside the furler using the empty hole next to where the head stay is held. Tack it the same as the jib.
Mar 22, 2009
360
Hoping the next time I can take down my 135 Genoa and install this Gennaker in the groove of the head foil furler. I doubt I can furl it though as I would probably run out of furling line before it was rolled up all the way.
I normally have my Genoa leads about 80% of the way aft for full Genoa. For the Gennaker I slid the leads all the way aft.
Could really feel the power when that big thing was full and pulling in 12 knots. If I wasn't running directly away from my marina I would have kept it flying for longer.
Trying to arrange a two-ship sailing formation with my slip neighbor for later this spring...so hopefully more/better pictures.
Cheers,
Jim
Dec 25, 2008
1,580
catalina 310 Elk River
It is difficult to get good pics of a spinnaker/gennaker flying on my own boat...too close. But here is what I got that day.
Cheers,
Jim
How do you jibe...the tack is outside the pulpit?
TLW
Jan 15, 2013
271
Oday 31 Whitehall, MI
OK, this is one of those times I should just keep quiet. I may be off-base, but as always - everyone's entitled to MY opinion!
I think what you have is indeed a GENNAKER. Not truly an asymmetrical or "cruising spinnaker." Yours has, from what I can see, cross-cut construction and no radial design. This is basically a big, 180%, full-cut, 3/4 oz. nylon genoa designed for relatively light wind and off-the-wind work.
The bolt-rope is actually a luff-tape designed for a Head-Foil, not a furler. The purpose of the twin groove head-foil is to allow the deployment of a 2nd sail before dousing the 1st sail. Obviously, you were able to fly this sail without a forestay attachment, but probably need firm halyard tension to do so.
Again, I may be way off-base, but think this is what you have. It is going to be more valuable to you as a free-flying sail, but probably not going to be able to sail as high as it was designed for.
Mar 22, 2009
360
I think you are spot on. But it seems to kinda/sorta work as a free flying spinnaker...and it kinda/sorta looks cool.
And I am kinda/sorta weirdin' myself out with this "kinda/sorta" thing...
And besides I just spent about $100 on a new tack line plus a block and shackle for the tack line and a snap shackle to attach it to the sail...
Cheers,
Jim
