circuit breaker source?
423
S2 9.2A Newport News, VA
Are the 12V panel breakers/switches still available? There's a spot on my panel for a fridge switch, but no switch.
I tried searching the forum, as I'm sure this must've been answered before, but my searches (even "advanced") seem to always search the whole site. I also looked at the factory letter, but didn't see a source for the panels.
Seems like the usual sources, like Defender and Hamilton, just see Blue Sea.
Thanks.
John
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Thanks.
John
try here John
http://shop.sailboatowners.com/cat.php?50885/Magnetic Circuit Breakers
that should do it
regards
woody
Apr 27, 2011
423
Thanks, Woody. I looked at the panel again yesterday and realized I didn't have anything connected to the spreader lights switch. I'll move that to the refridge position (assuming it's of proper rating) and put the plug in the spreader lights slot. I'll get specs off the switch/breaker and will compare it to the link you gave me. It'd sure be nice to have the panel fully loaded and even have a spare or two.
You're the best!
John
Nov 10, 2012
22
S2 9.2 ST IGNAGE, MI
I Got One From West Marine 2 Years Ago.they Had Them Is Stock At The Store. On Page 413 In The 2013 Catalog
Jan 25, 2011
2,437
S2 11.0A Anacortes, WA
are you going to label the breaker? I'm trying to figure out some nice loooking white lettering on a black panel.........
Apr 27, 2011
423
Bizarrely enough, the panel already has a factory "refridge" label, so that's not an issue. I'd like to label all the spares, though, that are now used for the autopilot, chartplotter, instruments, etc., and am thinking about buying one of those Brother label makers that supposedly you can buy black tape that it'll print white on. Or maybe it's just white tape that it inverses the image when it prints, so it leaves the text area white. I'll let you know how that works.
John
Apr 27, 2011
423
I do drive by West Marine on the way to work. I try to avoid going in there, if I can, as I tend to get in trouble. I need some blinders so I just head to the electrical section. I'll pull one of the breakers and take it in. And thanks for the page reference!
Guess I should drag out the Norcooler manual and see what the current draw is.
John
Styx
Sep 6, 2011
98
S2 8.0C Erie
I just bought 10 from Paneltronics.com. Part number for the 5 amp is 206-070s, 10 amp is 206-071S, 15 amp is 206-072s. Cost if you buy them off their website is $10.39. If you call them and order them on the phone, they are more expensive. I called, then sent a picture of my breaker and they emailed me back the same day with the part numbers. Then I ordered online. I received them in a few days and they work perfectly.
Mar 23, 2011
65
S2 9.2a Bradenton
The breakers are kinda standard /common. DC breakers can be used for AC, but AC breakers cannot be used for Dc. Ie the breakers you use for your home are not to be used on the boat...
You can Google DC breakers and find them in eBay...
Or most anywhere..
