Adding plexiglass to front hatch
chp
Sep 13, 2010
434
Hunter 280 hamilton
Just curious if anyone has cut out an opening in the front hatch and install tinted plexiglass to add some light to the front berth.
May 4, 2005
4,062
its been done. but likely to leak
What some have done is closed/sealed the front hatch and installed a real hatch in the fiberglass hatch. -that works much better.
try ebay lewmar / bomar
cscott
Oct 18, 2007
188
Macgregor 26S - 1993 Aumsville, OR
I didn't do this, but made a new front hatch out of plexiglass that allowed me to switch them any time I wanted more light or dark. I did this for my 26S.
Chuck
Jun 5, 2004
997
Macgregor 26D Boise
I'll try to get a picture up of my forward hatch window.
I used about 50 fasterns, SS nuts and bolts. Due to construction variances in the thickness of the hatch, The faster lengths will vary. On this kind of installation, I believe that it is necessary to drill the holes in the hatch and lens oversized, to allow the plastic lens to expand and contract. Also since this surface will no doubt be walked upon, the lens must be sized to have enough rigidity to deal with a persons weight.
The hatch has a wooden center. It is probably plywood covered with fiberglass and gelcoat. How tight you make the mounting screws is a matter of feel, don't want to crush the laminations. I mainly depend on the adhesion of the clear rtv to attach and seal this window. The nuts and bolts just locate it.
Never leaked a drop.
May 4, 2005
4,062
Chuck
can you please post a picture?
-and I stand corrected. -they don't always leak.... but note the expansion issues from oreana123.
Many boats used to come with solid forward V berth hatches, then they switched to see-throughs. First thing a lotta skippers did was cover the hatch with Sunbrella 'cuz they couldn't sleep in. Consider your personal habits before you do this. We have a solid forward hatch, and if I need light up there I either open the hatch (!) or use a flashlight. I sleep in, late sometimes, too. :)
chp
Sep 13, 2010
434
Hunter 280 hamilton
Hope you can get a picture up sometime. I would like to see it. Also good to know about the wood core. We never sleep up front. Too small and I store a lot of stuff up there. We always sleep in the aft queen size berth with a 5" memory foam mattress. I liked having the tinted hatches in the boat we chartered in BVI. Not that I need another project. It seems for every one I complete, I come up with 2 more I want to do.
cscott
Oct 18, 2007
188
Chuck
Sorry for such a stupid answer. I was thinking of the cabin hatch door, not the forward hatch cover up forward at the V-birth.
Put mind in gear before opening mouth.
Chuck
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
On my 23.5 Hunter,I added a Beckson Vent-O- Mate,it has a clear inside cover ,lets in light and vents at the same time.Easy install ,works great
chp
Sep 13, 2010
434
Hunter 280 hamilton
Just looked it up. That may be the answer. Kills 2 birds with one stone. I like it. Thanks. And not expensive and easy to install.
Kestle
Jun 12, 2011
702
MacGregor 25 San Pedro
Where do you keep the cash? :). Geez, that it built for a safe! There's not that much hull flex...
Jeff
Jun 5, 2004
997
Macgregor 26D Boise
3/8 inch thick dark tinted plexiglass. Routed the opening in the original hatch. Routed the edges of the plexiglass. Set with RTV, because it cannot be removed (there is a hole there now) , and because of how well attached the side windows were at the factory with RTV. I have replaced hatch windows because they expanded and cracked, so besides being attached to the top surface, the oversized fastener holes allow growth as well.
