For a complete understanding of the Catalina 22 and Catalina 25 swing keel pivot mechanism, start with the first article in this series: History of Retractable Keel Design
Swing keel boats are frequently sailed in areas of shallow water and are seldom equipped with depth sounders. The result is they sometimes run aground.
The Catalina 22 uses a locking bolt to keep the keel down in case of a knock-down. The Catalina 25 has no keel lock down system. C-25 owners may skip directly to
Keel and Pivot Pin Wear.
The Catalina 22’s locking bolt acts with friction against the side of the keel. When the boat is run aground, the keel is forced past the bolt. This feature is provided as a last resort to preserve the integrity of the hull. Problems arise when the keel itself is used as a depth sounder in lieu of prudent seamanship and current charts.
There has been much discussion over the years about the locking bolt design. The arguments align in one of two camps:
1) Lock the keel down whenever sailing. The manufacturer put it there for a reason. Use it. 2) Grind the locking plate out of the boat, glass it over and remove it for good. It doesn’t work anyway and just causes problems.
Although valid arguments can be made for either view, the locking bolt is there for a reason. In case of a knock down (where a combination of wind and sea heals the boat until the mast is in the water) the keel may try to swing back into the keel trunk. If this happens, the righting moment will change and the horizontal boat will become less and less stable. With the keel entirely in the trunk, the boat may actually “turn turtle” and go entirely upside down.
Second, if the boat were to experience a violent knockdown with its keel unlocked, the keel could swing rapidly into the trunk. There is nothing to stop the motion of the keel other than the fiberglass. When 550 pounds of falling cast iron meets a fiberglass laminate, anyone can guess which one will be damaged! Serious fiberglass damage may result, further compromising the seaworthiness of the hull.
On the other hand, if you are daysailing in the Chesapeake, there isn’t much wind, you’ve listened to the weather reports, and there is a high likelihood that you will run aground, it may be prudent to leave the keel unlocked for the moment. In areas like Lake Tahoe, where a placid day can change into a 30 knot blow in ten minutes, the keel should always be locked down.
