When the integrity of a mast has been jeoparidized, the best and safe way is to replace the mast. It has been suggested to insert a sleeve. Selden Mast company does that with the larger masts sometimes sleeving them; however, the inner sleeve is designed to specifically fit the inside of the mast extrusion which is safe and stong. The key to sleeving a repaired mast is the inner sleeve has to fit exaclltly the inside diameter of the damaged mast; otherwise, any sleeve will not work and cause failure at the rrepaired section causing the mast to collapse under load. I beleive the mast of that 34 was a Z Spar and that being the case, parts and masts can be obtained from U S Spars in Gainesville. Remember when replacing any mast, I would suggest going back to the same mast design with spreaders and you will probably have to take care of changing the rigging or whatever.
crazy dave condon
