Hi - I recently purchased a 1986 Oday 272. It has a CDI 4/6 (I think). The problem I am having is that the line guard rotates when I unfurl the jib. As a result the furling line wraps around the outside of the line guard arms rather than inside around the drum. If I carefully rewind the furling line around the drum, it will furl fine. It's only a problem when i try to unfurl the jib.
After inspection, I don't see anything that keeps the arms of the line guard from rotating. This is not the enclosed drum style. Instead it has 4 arms that come up from below the drum, one of which has a hole that guides the furling line. ref. K
What needs to be adjusted or replaced?
Thanks!
Thanks!
