Hello Members,
We took Breezin' Up, our 272LE out for the first sail today from Bokeelia. We had an exciting time and then put a reef in the main to make it a bit less exciting.
We had installed the sternrail seats before leaving the dock. Pictures are included. The wood is from a salvage shop. They were cut from one of those slotted covers that fit in the sole of a powerboat to cover the storage space for skis and such things. I copied the curve of each end along the centerline of the wood and then used a router to ease off the edges. Two coats of Cetol were applied.
The fittings were from ebay and the 1 inch ss tubing was from the same salvage shop as the wood. I need to adjust the length of the legs a bit, but we are generally pleased with the installation. The legs can be removed for storage in the fuel locker and then the seats can be flipped back behind the split backstays if the seats are not in use.
