I have vibration at higher RPMs. Engine alignment is pretty good. New strut and cutless bearing. Can worn out engine mounts contribute, and if so, how are they checked? 1979 Hunter 30 with Yanmar 3GMD.
Why should you occasionally check the motor mounts? .... all 'plastics' by definition are materials that slowly and permanently deform over time when stressed - called 'creep', a continual change of dimensions when under stress. Rubber although having exceptional elastic properties is still subject to 'creep' - its really by definition, a 'plastic'. (Rubber, could also be be defined as a 'liquid' with exceptionally high viscosity)I have vibration at higher RPMs. Engine alignment is pretty good. New strut and cutless bearing. Can worn out engine mounts contribute, and if so, how are they checked? 1979 Hunter 30 with Yanmar 3GMD.
Tom,Went down and took another look after seeing pictures and reading the discussions. My mounts look very good, not deformed, plenty of clearance. Motor quite firm to atttempts to shake it by hand. I recall the PO telling me the boat had been repowered, but I don't recall if he told me exactly when. From what I've read, I don't think the 79 H30 came with a 3GMD. My slip neighbor has an 81 H30 and his as a 1GM. Looks like I need to take another look at alignment to reduce the vibration. Thanks all for the input. Very helpful.
The shaft hasn't been pulled for inspection. I did try to find any run out when I did my last alignment, rotating the shaft while measuring clearances to see if they changed. Seem to be pretty consistent IIRC. I'll pull it on my next haul out. Not looking forward to trying to get the flange off the shaft.• When was the shaft last inspected for developed 'run out' ... no longer perfectly straight and now is 'wobbling' as it rotates.
See comments above and pictures below - Thanks!Tom,
Vibrations can be more than just coupling to shaft alignments.
* Does the shaft pass through the cutlass bearing perfectly centered? No. There was a slight twist to port. I replaced the strut and aligned it as best I could, but couldn't get it perfect
* Is it passing though the shaft log perfectly centered? Yes
* Is the stuffing box "side loading" the shaft in any way? No
* Where are you zincs on the shaft? None - I guess I better add one
* How many zincs?
* How high on the mount bolts does the engine sit? Roughly lower 1/3 of stud height
* How long is the shaft between the strut bearing and the coupling? About 3 ft
* Two blade or three blade? Two
* Has the prop been balanced? Not to my knowledge
* Has the prop been "lap fit" to the shaft? Don't know what lap fit is, but it seemed properly installed, no slop, good fit.
* Is the key in the prop "key bound"? No - keyway and key proper fit
* Is the shaft known to be straight/true? Unknown. I did look for runout at the coupling during alignment by measuring gap and rotating shaft and remeasuring. Didn't identify any runout.
* Folding, feathering or fixed prop? Fixed
* Is the gear box output flange true? See above - seems good
* Was the coupling "fit & faced" to the shaft? Measures good
* Has the coupling ever been removed & reinstalled? Unknown
* Split coupling or solid? Solid
* Condition of the motor mounts? Visually seem good. Rubber good condition, good gaps between metal parts. No sagging or distortion of rubber. Engine firm to "hand shaking."
* Are the motor mounts "pre-loaded"? Don't know what this means
Shaft coupling to gear box flange are but 1/10th of the alignment and vibration elimination equation.
You can have a perfectly smooth drive line IF proper installation procedures have been followed. They RARELY ARE FOLLOWED and is why the vast majority of sailboats vibrate horribly....
