New (to us) 1982 Catalina 27. Waste tank appears to be original Ronco B117. Tank outlet is 1-1/2" metal pipe (with nice green sheen to it), to a metal 1-1/2" tee; one side goes to a pipe elbow reducer, and then to 1.5" ID Shield Exhaust tubing to a manual diaphram pump and finally to a thru hull.
The other leg of the tee connects to 1-7/8" ID Shield Exhaust tubing to a 1-7/8" barbed deck pump out fitting. I have measured several times, and the fitting and tubing are definitely 1-7/8", not 1-1/2".
The vent fitting is a 3/4" MPT to 3/4" barb, with 3/4" ID braided Tygon (PVC) tubing connected to a 1/2" barbed deck vent fitting.
Attached pictures may help visualize.
I'd really like to replace the metal fittings with plastic and all the tubing with Trident 101 and 148. I was thinking of using 5/8" #148 for the vent, replacing the fitting at the tank and using the existing deck vent. I know it's small, but it's a short straight run.
The waste side will be trickier. The screw plate in the deck fitting is frozen (of course), as is the thru hull valve. So there's no way to empty the tank right now. I'm thinking of drilling out the plate, since I've got to replace the deck fitting with a 1-1/2" one anyway. That should let me pump, flush, clean, and empty the tank.
Now coming out of the tank I'll use a 1-1/2" pipe to barb elbow, Trident #101 to a Y valve, Trident #101 to a new 1-1/2" deck pump out, and Trident #101 to the manual pump and thru hull (fixing that at next haul out).
Does that seem reasonable? Any thoughts on brand of Y valve?
Thanks for all the great info and ideas I've seem here so far.
