H216 Spinnaker Kit - wanted.. have sail
Dec 1, 2008
18
Hunter 216 Lake Pleasant
Anyone parting out a hunter 216 or have a spin kit for sale? I have a sail - just would like the real kit vs my questionable setup.
Thx!
Joe
Jun 1, 2004
8,007
What kind of spinnaker? Does it look like this asymmetrical chute? If so, you just need to rig it correctly... the halyard block should be above the forestay hound on the mast... it should swivel. The tack, at the bow, should be adjustable so you can adjust its height, and the sheets should have "tweakers"... small blocks or rings with a control line that work like jib fairleads. The sheets are led outside all other rigging to allow you to jibe the sail by letting it cross over ahead of the forestay. The sheets should be 2 times length of the boat and led as far aft as possible, if you are using tweakers.
Mar 20, 2004
1,730
The spinnaker kit also includes the carbon sprit, mounting hardware, and the retract/extend tackle
