Fresh water zincs, take heed...........
This note is a side-light on the subject of zinc replacement that should be of interest to boats moored in fresh water. An important fact of life for boats that live in fresh water is that calcification on the surface of your zincs occurs as a result of contact with minerals present in fresh water, in a few months time. This process creates a very nice protective coating on your zinc. The trouble is, it's protecting the zinc from corroding as it is intended to! It is possible to grind away this calcification when the boat is hauled, or the zincs are removed, but I choose to replace mine each time I haul, about once/year. We are fortunate to be moored in a spot that has very few if any, stray electrons floating about. As a result our zincs remain virtually untouched by galvanic corrosion. A local surveyor, Allison Mazon, alerted our Hunter club to this fresh water problem. One that can have serious consequences if ignored for a time, with the boat subsequently moved into a "hot"(stray shore power) environment. If your zinc is covered with calcification, which looks like whitish/tan chalk covering the zinc; the next more "noble" metal below the waterline of your vessel is likely being dissolved even though your zinc retains its as-new shape. Beware your prop, or worse, your thru-hulls! As "fore-warned is fore-armed", I wish you hppy sailing, and may your prop and shaft stay as-new and your thru-hulls tight! Ron Hughes s/v Best Revenge, H 40.5.
