Mike
Help!My O'day 28 which is a mighty fine boat has an OMC Zephyr Sail Drive which isn't quite so fine. While it is true that it is simple uncomplicated beast it has many, many other not-so-redeeming characteristics.It has an ehaust fumes leak somewhere in it and I have consulted a qualified marine mechanic who is fairly certain that the crank seal is leaking allowing fumes to escape and as a result the engine area has a lot of oil on and around the engine. The mechanic feels that a rebuild would be an appropriate thing to do and I agree.The problem is that he hasn't been able to locate a rebuild kit and is hesitant to pull the engine if he can't find the parts to make it right. Is there a source out there for such kit and is there a source for parts other than the rebuild kit.I read in one of the forum postings that someone replaced his engine with a diesel to the tune of $11,000. A very good idea but a bit steep for me.So I repeat.... HELP!!!Thanks,Desperate in AuGres (Michigan)
