Looking for advice on emulsified oil and engine care. We have a yanmar ysm8 in a 1979 oday 28. It has been out of the water for approx 3 years. We have found for certain that we have a cracked cylinder head and emulsified oil. We have the head off the motor and made a gasket and wood form to seal the block in order to determine if the block is also cracked. By removing the head a lot of the oil has ran out of the block but there is still enough to see it on the dip stick. We ran water into the block at the water intake point and pressurized with running water. We were checking the dipstick to see if we could see any sign of a fluid rise. We also had the oil filter cylinder off and that opening visible. We did not see any indication of water coming into the crankcase. We are working on this motor on the weekends so it is sitting as is. Should we fill the crank case with oil or some other fluid while sitting. This is the first weekend that it is sealed again by using the wood form/gasket. The head is still removed. There is some visible rust seen looking through the motor oil entry. The cylinder and oil filter cavity are clean and free of any corrosion. We are also trying to determine best method of cleaning the emulsified oil. We are thinking automatic transmission fluid to start with and then drain or I should say siphon as there is no drain plug. Then cycle some 10/40 oil a few times. Recommendation???
