I am planning to replace the cylinder liner in my YSM12 as part of a rebuild. I have not removed the old cylinder liner yet. The Yanmar shop manual is confusing about the construction of the YSM12 cylinder liner. The detailed drawings indicate that the outside wall of the cyliner liner is smooth. The instructions specific to the cylinder liner wall indicate that there are two grooves machined for the O-ring seals to seat. The liner that I have in my hand has no grooves for the O-rings to seal, it is smooth as indicated in the detailed drawings.
My question is: have any of you replaced a liner in a YSM12? If so, are the grooves for the O-rings machined into the cylinder liner or into the engine block?
The shop manual tells you to install the O-rings on the cylinder liner before sliding the liner into the block. It would appear to me that you would need to install the O-rings into the block before sliding in the liner.
Any lessons learned on a YSM12 cylinder liner replacement would be greatly appreciated.
