So as not to hijack the other fuel line thread, I'll start anew with a slightly different problem that has occured after I bled the line.
We had lots of water in the tank and through the filters.
So I removed the Racor primary, the engine mounted secondary, all fuel lines from the tank to the lift pump, cleaned them and installed new filters. I had the tank drained, cleaned and polished fuel returned to the tank. I bled the fuel line and confirmed good fuel going to the injector.
Engine now starts as normal, with only a count of three on the starter.
It then runs normally for a few seconds and then dies.
I've looked for fuel leaks to indicate if one of the various connections/seals is loose and so far haven't found any.
I think air is getting in the fuel line somewhere.
First question: Is an air leak likely to be after the Racor? The Racor bowl stays full.
If the fuel return line to the secondary filter got dinged, would that cause the problem?
Why would the engine repeatedly get enough fuel to start but then quit running?
Thanks for any insights you folks might have.
