Needless to say I am delighted!..... Checked the oil, connected a hose pipe, primed the fuel pump a few times, jump leads to the car and she started straight away!!! Runs as sweet as a nut - I had assumed I would need to replace the engine but this boat is getting better every day!
The control lever (in the cockpit) had to be disconnected - it is still seized solid - I just moved the lever on the engine and everything seems to work. Just a thought - the prop was turning all the time the engine was running ie there does not seem to be a neutral - is this correct? - oh... and the direction of rotation is always the same - how do I select reverse?
Steve - do you sell new control levers?
