Hello all-
Having searched through the archives looking for an answer, I find myself still looking for answers and advice. Among my many winter projects are the replacment of the batteries and charger on our Hunter 340.
The PO had 4 6v GC batteries AND the starting battery crammed into the starboard aft lazerette, which not only caused the boat to list to starboard when at rest, but actually busted the floor of the laz, placing at least a portion of the considerable weight of the batteries on the holding tank below. Not good. As a temporary measure, I have reduced the house bank to 2 GC batteries, which still live in the same laz with the starting battery (after repairing the floor of the lazerette, of course). The batteries are about 8 years old, so I figure they're pretty much due for replacement.
What I would like to do is return to a 4 GC house bank (Sam's Club), plus a dedicated starting battery, with a new (smarter) charger. The current charger is the original 30A Newmar that came with the boat.
Here's where I run into some issues. Obviously, I can't cram all of these batteries back where the OP had them - lest I create the same problems that I had before. I would like to leave the starting battery in it's original location in the starboard aft laz, as there is a shelf built in there that seems to be dedicated to that purpose. There is no place on the boat that will reasonably house all 4 GC batteries together in one place. There is a nice space between the holding tank and the diesel tank where I could fabricate a shelf and house 2 of them (on the centerline of the boat - essentially under and between the lazerettes), with the other 2 possibly housed in the port aft lazerette (which would eliminate the "lean"). The run between the two locations would be around 5'-6'. The charger is currently located in the same compartment as the starting battery. The run from the charger to any of the proposed battery locations would be less than 8' (16' round trip).
So, all of that probably being clear as mud, here are my questions:
1. Are the GC batteries close enough to one another to wire them together as a single house bank, or would I be better off to utilize them as two separate house banks?
2. Are any of the distances from the charger to the batteries going to be cause for concern?
3. The Webasto diesel heater is also located in the port lazerette. Though there is plenty of ventilation and the heater is utilized infrequently, what are the potential issues with housing batteries in the same compartment?
4. Any recommendations regarding brand/model of charger/battery monitor would be greatly appreciated.
I know it seems like every third thread has someting to do with batteries/chargers/solar/etc. - and y'all are probably weary of talking about it. But, as this is one of the more critical systems on board - I want to get it right so I don't have to worry about it.
Thanks to all in advance for your help.
