Hello:
In my 1968 Vega the bilge drain screw was portside. I removed it. Also
the foam that filled the keel aft of the ballast was full of water.
When the water in there froze in winter it oozed reddish water pus out
of blisters in the side of the keel. I opened that keel area, removed
all the old foam, put another layer of glass mat inside with epoxy
resin, sealed it back up, and re- filled it with closed cell foam. It
was a mess but is stronger now and the fiberglass in the keel does not
get stretched when it freezes and expands.
You could be getting water in your ballast but the Vega site says that
the ballast is encapsulated with 1/2" of fiberglass.
Good luck
David Ham
Juneau, Alaska
Good luck
David Ham
Juneau, Alaska
