yatch specialties pedestal parts
jtmccue
I have an early H28.5. The pedestal's "!plastic!" housing thru which the throttle lever's axle travels, broke/cracked. It just busted out of the whole that holds the axle which takes a lever mounting for the cable on the inside. Are these "housings" available anywhere or do I need to try super glue it, then drill in to make a stud - then reinforce the fitting with some fiberflass screening and pack it with autobody filler. Anybody have this happen to them and what did you do??
Dec 2, 2003
4,245
- - Seabeck WA
We're not ignoring you, it's just that your
system seems unique. Mine is aluminum, not plastic. Never heard of a plastic YS lever system.
Jun 21, 2004
88
Hunter H31 Niagara Falls
See if this helps
Ceck the link out. It goes to a thread in the archives. Its a similar problem and includes a source for the new part, but its expensive. Please report back on the outcome.
