Same Problem
I had the same problem two years ago on my 37.5 while I was preparing to drop anchor out in the Marquesas. Fortunately, we had a full boat of people and were able to work out a signaling system to the guy who had to be down in the engine compartment manually shifting the transmission. This made for an interesting time docking when we got back to port. Having a yard do the work was not an option on this trip, so we had to do the replacement ourselves. First, the pedestal did have to be removed and the bolts were seized big-time. For this, we can thank Edson and their use of stainless in contact with aluminum without any "protection". (By the way, this same problem exists on the steering quadrant, where the carbon-steel stop is secured with stainless bolts onto the aluminum quadrant. The bolts seize and the stop rusts and drips down on the swim platform.) But back to our story. On my boat, the problem appeared to be due to the cable running through a space between the pedestal and a ~spacer plate that was too narrow for the cable. This caused excessive friction and ultimate failure. In order to not have to deal with this big job again, I did two things. First, I got two "Morse 33 Supreme 16" cables. These are reportedly the best cables on the market and are usually used in aviation. Second I installed these two cables in parallel through one of the larger spacer plate holes, with the spare secured at each end of the run. This way, if another break happens, I'll just have to connect the new ends. Things have gone well ever since, with much easier shifting. Overall, this job took many hours. But, I agree. The yard should have contacted you. Hope this helps for any others who want to do pm on this area of the boat. Robert Pancza
