Yanmar Yse 12 transmission
Jan 14, 2011
243
tanzer tanzer 28 bathurst nb
My trans has a coui coui, any common problem with yse12 tranny, i have a fresh rebuilt engine. So fixing the transmission is a priority.
Tanks
Feb 9, 2014
1
Bayfield 29 cutter Guaymas, Mexico
I have an excellent used one, in Mexico, that I would sell if yours doesn't find its fix!
Jan 14, 2011
243
It was a piece of fishing net melted and tangled in the prop
Jan 14, 2011
243
The diver found out that there was only a little bit of algae on the prop, so after further investigating, it was found that my shaft coupling was worn out. An alignment problem cause a small wobble to turn into a bigger one, so the shaft was moving forward and rubbed the prop against the skeg making the noise....
