Yanmar YM30 Oil level
Jan 2, 2015
35
Beneteau 340 Oceania ventura
filled with 3L of oil per manual. The Manual also says to fill to upper mark on dipstick though the 3L only makes it half up to the upper mark. I don't to overfill. Should I just keep an eye on it..... add a little after running a bit.
Jun 21, 2004
2,903
Beneteau 343 Slidell, LA
Just changed oil on my YM30 a few weeks ago. Took about 3.5 quarts and I didn't change the filter (only about 15 hours since previous filter change). As long as you are inbetween the marks on the dip stick you should be OK; however, I would add another 8 oz to get the oil level further up the stick. Be sure to let motor sit for 10-15 minutes to ensure that all of the oil has migrated into the oil pan before adding oil.
Jan 2, 2015
35
Yes I replaced oil filter too. Going back today to check level and can top off a bit if needed
Thanks for the suggestions
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Don't overfill it. Assuming that the engine sits on a bit of a fore aft angle, the dipstick can read a bit low. Overfilling could cause issues with foaming as the crankshaft churns up the oil in the pan.
