- Oct 22, 2014
- 23,301
Met a new sailor with a Jeanneau 34.2 and Yanmar engine.
Says the transmission or prop shaft sing/ hum when under power between 1400 & 1600 rpm. Then it stops. When sailing at about 6.2 knots there is a growling sound. It also stops below 6.2 or above 6.5 knots.
Any ideas? What is the recommendation for the transmission when sailing? In gear in neutral? He said he thinks he has a prop and straight shaft with a strut.
