Same problem
I have developed the same problem with my 3GM30F. Do an archive search and you will find this issue addressed in older threads. There is also some discussion on it on the Torreson Marine Diesel site which is linked in some of the earlier threads here. I have a friend with the same model boat/engine and he has also had this problem. He replaced the starter a few weeks ago and it DID NOT solve the problem.I did some poking around on my boat this past week and found at least three disconnects in the wire from the button to the starter (2 bullet type and 1 spade connector). I pulled each apart and cleaned them with emery cloth so there's a good clean connection. I also gently crimped the female end of the spade connector (this one is on the wire about 4 inches from the starter itself) so that it has a tight "grip" on the male end of the connector. I don't know if this solved the problem yet, but my boat is a '99 and this summer was the first time this has happened, suggesting to me that the problem happens with age, i.e., corrosion of the connectors. Another fix would be to run an uninterrupted wire from the button to the starter, and just disconnect the old wire in at least one place. Label the old wire and new one for future reference.FYI, there should be two wires coming out of the back of the button switch, one jumps over a short way to the key switch and this is the wire that supplies 12V+ to the button. The other wire (mine is white) weaves its way through the wiring harness and down to the starter. Just trace it from the button switch and you'll find all the connectors. Turn all BATT masters OFF before you start doing this.As a last resort if you can't get the button to work when out on the water, and IF you have enough space around your engine to SAFELY reach the starter, you can always start the engine by disconnecting the spade connector near the starter I mentioned earlier, and touch the short end (male end, wire coming from the starter's small terminal) to the large BATT terminal lug right on the starter. That applies 12V from the batt directly to the starter solenoid and will engage the starter. DO NOT DO THIS WITH LOOSE CLOTHING OR DANGLING OBJECTS ANYWHERE NEAR THE ENGINE! KEEP YOUR HANDS, FACE, AND BODY AWAY FROM THE BELTS AND PULLEYS!
