Jim
I have a problem with engine starts with my Yanmar 2GF20(F). It just developed recently. When I am out sailing and ready to restart the engine by pressing the start button, nothing happens. Some times I have to press it really hard 3 or 4 times before it would start. But if I start the engine in the slip when getting ready to go out, it always starts on the first attempt. I wonder if I have a problem with the switch (push/release type) or starter or the batteries. I do day-sailing and the only other power consumption is an autopilot which I use may be 30 to 60 minutes or so when I am out. I have two batteries, both deep cycle, one DP-24 the other DP-27. Both battery are flooded types and are about 6 months old. I use a battery switch that has "1-Both-2-Off". I normally keep the switch on "Both" and charge them with shore power about 30 minutes/day using a timer. I would appreciate any suggestions on what may be the cause of my problem.Thanks
