Engine Control Cover
Hi Jeff, My 2003 466 has the old Hunter design engine control, with no cover, as the newer hunters now have. I'm fabricating a cover in the coming weeks out of starboard and clear plexiglass for the reason you mentioned as well as in response to a sticky start switch that ultimately cost me over $2k to fix.... The starter switch stuck on during an emergency maneuver without the helmsman knowing, frying the starter. All because of a balky $10 switch.I spoke to hunter about retrofitting a new yanmar panel and none of the wiring harnesses are compatible, hence the custom fabrication.If you are interested I'll send you photos when done and any lessons learned during fabrication.allan
