Yanmar SB-8 Zinc
12
- - Deltaville, VA
On my YSM-12,
it is under a plug on the top of the engine near the thermostat housing. It has a square shoulder for removal. The zinc screws into the bottom of this plug. Since these are similar engines, your's may be in a similar place.
TONY A
Mar 7, 2005
30
Hunter 30_74-83 JACKSON, NJ
YANMAR
I FOUND A GREAT YANMAR PARTS SITE. THEY SELL PARTS MANUALS AND SERVICE MANUALS, WORTH THE MONEY. I PROVED TO MY LOCAL PARTS GUY THAT THE 2QM15 HAS 2 ZINKS, WHEN HE WAS TELLING ME ONLY ONE. WWW.MARINEDIESELDIRECT.COM FOLLOW THE YANMAR LINKS.
tmason
Jun 11, 2004
29
Hunter 27 Cherubini Middle River
under a right side plate
As you are looking at the SB8, there is a plate on the right side of the block with a stud and a nut mounted on it at dead center. The stud is a part of the zinc, but take the plate off first. You'll need a rubber washer and a gasket in addition to the zinc. www.dieselmarinedirect.com sells these parts. If you find the zinc supercorroded and the block full of crap, you might consider removing the head and the exhaust manifold to make sure that the water jacket isn't gunked up to the point of localized overheating.
