Not getting water out the exhaust when engine (2QM15 - raw water cooled)warms up.Was pumping plain water fine when cold (from a bucket - boat is "on the hard")and then I started running antifreeze and the flow stopped and the engine temp warning light came on. Water (and antifreeze)does seem to be getting to the block (plenty drains out when I disconnect the inlet hose). New thermostat had no effect. Is this an exhaust manifold jacket clog, an impeller that's too weak to pump antifreeze (but can pump water!) or something else? Because water is going out the mixer elbow when cold, can't be a clog there.
