I'm still having a problem with my 3GM yanmar getting air into the fuel system, after it sits for three weeks or so. Will not start after this amount of time without bleeding the fuel system. I posted up on this pretty good while back, and got lots of answers/suggestions. What I have done so far is replace all the fuel line from the tank forward. Put a "t" in the system with shut offs on both sides to isolate the electric fuel pump. Checked/replaced all the gaskets on the fuel filters. Replaced all banjo washers. Gone over every fitting and hose clamp making sure all is tight. And of course visually inspected every inch of the system for any sign of fuel leakage anywhere. I can turn on the electric fuel pump, put 4 lbs of pressure on the system, and it will hold pressure indefinately. My question for you Yanmar guys. Is it possible for the lift pump to have a bad check valve or a pin hole in the diapharm, that will allow air in, but not allow fuel pressure to leak off. The air is definately getting into the system before the high pressure pump. I can bleed it there, get air bubbles, and the engine will start and run fine, so it is NOT in the high pressure pump, or that side of the system. Only thing left that I can think of is something in the lift pump, but the fact that it will hold pressure doesn't fit with that either.
